Help wiring footswitch with led!
  • Help wiring footswitch with led!
    I need some help wiring a footswitch with led for a fender reissue amp. I have the enclosure, 2 dpdt switches, 2 led's, cables, everything partswise. Now could somebody help me wire this thing? Input on the Amp is a 1/4 jack.
    A liitle wiring diagram would be great.
    You don't mention which model amp you have but footswitch wiring will be on the schematic:
    Amplifier Schematics
    The LEDs might be superfluous though, unless you want to put a battery in the enclosure.
      It's a princeton reverb with standard fender footswitch.
      I want to build one myself with led and battery into a hammond case connected with a stereo jack. I have all the parts, just need help with the wiring.
      A small layout would be georgeous as I'm not shure how to connect everything.
        Excuse the drawing, stole the nice part of it from the 65 Princeton Reverb schematic on the Fender site.
        Can you follow this OK?
          aaahhmmm, more or less. I'm not that good with schematic buth thanks anyway.
          I'll try to make a layout out of it.
