I'll play around with that on my next SF project. My TR has a Vari-Watt now so if I want power tube distortion I just dial back the B+ to the 6L6's and I can drive them hard without needing to put on hearing protection. Lift the ground from the mid pot to overdrive the preamp too and it sounds NOTHING like a Fender anymore, but that is beyond the scope of this thread.
Silver face vs black face
The way I frame it is that the SF circuits were themselves modifications of the earlier BF circuits. What I do when I mod SF amps for clients is undo some of the circuit mods that the CBS engineering staff introduced.
"Matters of taste" and all, but I will say that I have yet for a client to take me up on my BF mod guarantee, which is that I will reverse the mods and refund that part of their repair fee if they are not happy with the sound afterward. Usually it's more like their jaw hits the floor when they play their first chord through the BF'd amp.
The standard package of BF mods I do is: global bias, 220K bias feed resistors, 100K/82K plate resistors & 1M grid leak resistors on the PI.
Originally posted by Euthymia View Post... Usually it's more like their jaw hits the floor when they play their first chord through the BF'd amp.."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Originally posted by JoeM View PostPeople will hear what they expect to hear. None of the changes you make would cause a great difference.
When I first started fixing amps full time, the only BF mods I routinely did were the 220K resistors and global bias, and then I decided to try the rest of the popular BF mods. I did them one at a time, and some of them actually did make the amp sound different (more pleasing to my ear). Some of them did not, and I do not do those.
I'm not in the business of selling snake oil; for instance when I do filter cap jobs, I use whatever off-the-shelf generic electrolytics I get from my distributor. I tell people that if they want to source Sprague or whatever, I can install them, but I don't bother to keep them in stock. Same with most other parts (not tubes, of course). When people ask me what kind of caps I use when I replace coupling caps, I just say "film" and leave it at that. If people want to bring me fancy components to install, I am happy to do so, but can't be bothered to keep them in stock for repairs.
The "BF" mods I make are audible, and the difference they make is not what I consider subtle.
Originally posted by Euthymia View PostThe "BF" mods I make are audible, and the difference they make is not what I consider subtle.Last edited by JoeM; 02-02-2011, 03:14 PM."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Originally posted by JoeM View PostSorry, but I just cant buy that. But if your customers do that's great.
To suggest that this stuff is not audible is quite a stretch.
Originally posted by m-fine View PostJoe, have you never adjusted the bias on an amp or turned a tone knob? The changes are easily audible and the reason they are is well know, well understood science. You can easily model how these things impact frequency response before you heat the iron up. This is not snake oil $100 coupling caps, we are talking about different resistor and cap values that significantly change voltages, bias points gain and frequency response in highly preditable and measurable ways.
To suggest that this stuff is not audible is quite a stretch."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
If you take two twin reverbs, use the same speakers (hook them both to the same cab) and use the same exact tubes, you can have a pretty noticeable difference. Assuming you use a matched set of power tubes, baring luck, the simple fact that you CAN "properly" bias with one and not the other can be a pretty noticeable difference on it's own. All of the other changes are additive so I would not critisize Erik or his customers for hearing the difference and feeling it was more than subtle.
We can argue whether some of the changes make it sound better or worse, but they definitely sound different.
One aspect of the BF design I don't see discussed that much is the fact that, according to the original 6L6GC datasheets, the maximum control grid resistance (i.e., the grid/bias feed resistors) for a 6L6GC is 100k when using fixed bias. With 220k resistors, you're over twice the published limit. I may be prejudiced because the first Fender amp I did major work on was a SF Super Reverb that had had some BF mods, and it was having problems with the output tubes going into thermal runaway. Before someone starts saying, "Well, did you check...." Yes. I checked everything you could possibly mention, and the output tubes were Philips 7581As.
Or, let me put it this way: has anyone checked, when going from 100k to 220k, for an increase in grid emission, which you could measure by monitoring the voltage drop across the 1.5k grid stop resistors?
I'm perfectly willing to accept that 6L6GCs can tolerate 220k grid-leak resistors if that's the general consensus. I put some 1960s GE 6L6GCs in the amp mentioned above, and, according to its owner, it has not red-plated in the year and half since I worked on it (with 220k resistors installed by a previous tech).
Definitely an area where the SF amps got it right. I think this was posted above, but here's something from Aiken amps on blocking distortion:
Fender amps are particularly susceptible to this because of the large values of coupling capacitors on the grids of the power tubes (0.1uF). Blackfacing your Super Reverb can actually make the problem worse, because you change the grid bias feed resistors from 100K to 220K, which increases the time constant of the AC coupling to the output tube grids. You will note that most Marshalls use 0.022uF coupling capacitors and 100K resistors, which gives a much faster time constant. In addition, the preamp stages have a much more rolled off low frequency response. This is why they sound tighter when played wide open.
I've used 150K with .047, which helps too."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
