Ok, I have a Crate Blue Voodoo 120 and two 4 x 12 cabs. One cab is a BV cab and can be set at 16 ohms or 4 ohms. It also shows that it can run 8 ohms if used in stereo. My other cab is a 16 ohm Peavey XXL cab that I use for practice etc. The amp has a selector switch that lets me choose 16 ohms or 8 ohms. I would rather run 8 ohms but am not sure how to get an 8 ohm load from my cabs.
I've been searching online and can't find anything about it. The amp has two speaker outs, one labeled main(use first) and the other labeled ext. speaker. Can I run a cable from each of those outs to the stereo inputs of my cab to create an 8 ohm load?
I've been running everything on 16 ohms just to be safe, and would really like to try an 8 ohm load. I really don't want to use both cabs at the same tie, but might like to have that option as well someday.
Any ideas?
Any ideas?
