Like a race car is just a car if you obey the speed limits and just drive to the store.
EL34s and 6L6s working together in perfect harmony
Originally posted by Steve Conner View PostThis has been debated to death before. I like to make the distinction between design class and operating class.
Originally posted by Ramsay View Postyou're wrong.
Changing the voltage bias don't change the amp class to A, AB1, B or D.
Because it depends of the construction and project of the amp in itself.
Say if your power tube cuts off at control grid at -51V with a given +B, Say if your expect max input is 20V peak. If you adjust the control grid to -30V, This is class A for the given input signal. Even the input signal is at the most negative, it is -20V, together with the grid bias at -30V, the tube just at the verge of not conducting but still have a little current. So the tube is conducting in 100% of the cycle and THIS IS CLASS A.!!!!!
BTW, this has nothing to do with single tube or two tubes in push pull mode. You can have single end class A or you can have a pair of tubes bias in class A push-pull. Just follow the definition of what I said in the beginning.
Today I bought a brand new pair of Groove Tubes 6L6 Red.
So I will pull out the four EL34 tubes to put the 6L6's.
To play at home, I don't need more than 50W and for my taste my amp sounds better with 6L6's instead of EL34's.
How I use a resistive power attenuator, I will rebias the amp to use 50% of the rated dissipation plate of each 6L6.
With that I think I will be satisfied with the amp working at AB class.
