I recently acquired an old Pine Electronics (aka-Pepco) amp that is in need of some TLC and I'm an absolute novice who is looking to gain some knowledge about guitar amp workings. I do know enough not to get electrocuted and am doing some reading, but my experience is at virtually beginner level.
This amp has an old cap can, that I believe is 3 caps in one, that is marked as such:
Plessey UK
20-10-10uF
Red outer - 20
Plain inner - 10
450V max wkg
525V surge
CE 8641/13
Dec/67
The tube compliment is : 2 X 6AV6 ; 1 X 12AX7; 1 X 6V6; and a 5Y3 rectifier.
What I would like to know and get advice on, is what if anything should I do to possibly bring this amp up to speed. It does work, but sounds a little lackluster and I think the 6V6 cathode resistor is blown, as it looks as such and it reads apprx 230 ohms, it should be (I think) 470 ohms. This amp came in a monster cabinet with 2 really crappy original 8 ohm 12" speakers wired in series to take the 4 ohm output from the OT. I put the chassis in a small ARC brand cab, also made by the same Montreal manufacturers of this amp and hooked it up to a new Weber 8" 4 ohm SIG8S speaker, that sounded so very much better than the 12" ones.
Firstly, I think I should replace the 2 prong power cord with a 3 prong and would like to know if I should reconfigure how the present incoming leads are wired , I do know that the new ground wire will have to go somewhere on the chassis. Also, should I remove the cap going from the fuse to grd? Is this what is known as a "death cap", because there is no ground lift switch, which is usually present with that type of cap, am I correct?
I am especially concerned about the age of the main capacitor(s) and was wondering if it should be replaced due to it's age and if so, should I get a similar style cap can or 3 individual caps and just secure them to the chassis, thus avoiding messing with a heavy duty soldering iron needed for the big can replacement. If the 3 singles are the way to go, could someone tell me what kind of value caps I should use and exactly how to wire them in relation to the existing can terminals. I realize that this is similar to a Fender Champ style amp and know it is primarily a practice amp, but I feel it's a good place for me to start learning, as the wiring is so basic and accessible. Also, I'm thinking of adding an on/off switch, currently the volume pot is serving that function. Should I bother with that, as I thought I might put new pots in anyway? I also am not interested in the tremolo feature, which really sucks anyway, should I remove that. What is the exact function of the 6AV6 tubes? I have a lot more questions than knowledge.
I am posting some pics and if anyone has any suggestions of any kind, I would really like their input.
Dan
Plessey UK
20-10-10uF
Red outer - 20
Plain inner - 10
450V max wkg
525V surge
CE 8641/13
Dec/67
Dan
