Jcm2000 Dsl 401 Not changing channels
    ok
    looked here
    and led 3 is the green led - clean channel
    pin 9 & 10 conectec to chassi
    i dont have the foot here to see if it works ,
      hello guys
      And I did it, fynally it worked
      started to heat up the solder, cleaned everynthing and replaced the C3 capacitor.
      and it worked
      thank guys for the help
      i learned a lot with this
      a last thing wat is correct bias regulation for this amp?
        There is a 3 pin test point for setting the bias. Factory setting is 1.375VDC from the center pin to either outside pin.
          Ah Ha! Just worked a bunch on this amp too. Tons of problems to fix and then I added similar problem w/ clean channel not working and led not lighting up. I replaced T1-T3 and it fixed the problem.
          However, I kept wonder on the schematic what CON5 was for....? My guess is that is the 3 pin test point for setting bias.
            Originally posted by hutsch View Post
            hello guys
            and it worked
            Correct?
            Depends on what the tubes draw at the given platevoltage. I'll recommend learning how to bias in general, but I can say you probably want a platedissipation around 55%-70% of the tubes maxdissipation. Look up the datasheet for the tube (probably EL34 in dsl)
              It is a DSL401, which uses EL84. I thought the factory schematic had a bias test point recommendation.
                Yeah this is the bias page that I have w/ the schematic for the DSL 201/401 models.
                  JCM2000 DSL combo manual channel switching issue of no clean (green) channel.
                  [QUOTE=hutsch;244777]hello guys
                  And I did it, finally it worked
                  started to heat up the solder, cleaned evernthing and replaced the C3 capacitor.
                  and it worked
                  How I fixed my MARSHALL JCM2000 DSL combo manual channel switching issue.
                  PROBLEM: Green LED and therefore "Clean Channel" not operating from front panel switches. (Although OK via foot-switch)
                  DIAGNOSES: All channels switched via foot-switch so I was doubtful that there was a component issue.
                  Due to this thread I zoned in on the foot-switch input jack. Thank you all.
                  SOLUTION: Looking at the foot-switch socket, there are 3 spring-metal "clamps" that open to allow contact with the foot-switch plug when it's inserted.
                  I found that the tip connector (the most innermost "clamp" ) was not springing back hard enough to create an electrical connection when the plug was removed.
                  So I inserted a plug all the way in, thus opening the tip "clamp" with the tip of the plug. I got a screwdriver and forced/bent the end of the metal clip downwards around the tip of the inserted plug.
                  Upon removal of the foot-switch plug, I immediately heard a "click" and the front green LED turned on. I then tested the 3 LEDs & channels with a guitar via manual and foot-switch operation.
                  Fixed!!! Hope this helps someone else.
