Hi. New to the form....however I have been viewing it for some time now and have decided to join up...Hopefully I can be of some help to members and they can be of some help to me as well...I am trying to repair a Hot Rod deluxe for a friend of mine which has a very bad hum problem which can be adjusted with the volume control....turn down the control and the hum goes away, turn it up and the hum gets louder the higher you turn the volume control. If you kick in the drive and more drive functions, then this hum becomes unbearable. New tubes, one new power supply cap,lots of bad connections, etc...replaced the plate load resistors because the amp was cracking.The amp has lots of volume but can't get rid of this nasty hum. It has dual 6l6's in it. The hum is there even without an instrument plugged in. Looks like there are new input jacks installed......Checked out the 47 uf/16V capacitor for leakage in the first stage......tested ok. Anybody got any ideas????I am open to any and all suggestions no matter how simple or bazzare they may seem.
Thanks.
Thanks.
