Mark I stated that I'd finish my post later. As I had to tend to something. I'm merely trying to achieve symmetry on P1. Which I did when replaced TR4/6 with 22k resistors AND disconnected the 56k feedback resistor. I decided on 22k as those are what I calculated would provide me with ~500ma of current. After this I reinstalled TR4/6 and am back to having bias problems. Both sides of P1 are close to the negative rail at -53v. I then thought maybe I damaged TR4/6 in this process. Maybe TR4 is open or TR6 is shorted. Nope, still the same issue after replacing them again. I have checked and double checked that all connections with my meter, from lead to lead, are indeed connected. I cannot for the life of me figure out why TR4 collector is at the negative rail ( and P1, and TR6 collector). Of note is that I removed C18 thinking maybe it was leaking and pulling TR4's base down and turning TR4 on harder, but no change in results here. Here are voltages on TR4/6
TR4
B/E: -560mv
TR6
B/E: +600mv
C/E: 160mv
R21 has 520mv across it - thus TR4 is on and drawing current.
R23 has 1v across it, which makes sense if both TR5/6 are pulling current through it, so TR6 is on too.
R22 has 460mv across it so TR5 is on too.
TR5
B/E: 600mv
I'm quite confused as everything seems good with the meter, however P1 is at the negative rail!! ??
TR4
B/E: -560mv
TR6
B/E: +600mv
C/E: 160mv
TR5
B/E: 600mv
