swr workingmans 15
  • #31
    i have all the ic remove from pcb then give the amplifier bum...beep...bum ...beep
    • #32
      ok R74 where can i find it on pcb ? or housing
      oke R74 waar kan ik deze vinden op de print ? of behuizing
      I do not see it, maybe it is under the board *or* they used fixed factory selected resistors.
      Just curious, measure voltage from ground to 3 FET 2N5457 (Q13) legs, I think it's the metallic one.
      2 should be 0V DC, one should be around -5 or -6V (Fet bias).
      i have a velleman DVM345DI mulitimeter voltage setting automatically
      ik heb een velleman DVM345DI mulitimter voltage gaat automatisch geen instellingen dus
      Good multimeter.
      i have see 0.220 ac with connect c13 preamplifier
      ik zie hier 0.220 ac op luidspreker uitgang en c13 is weer door verbonden
      Good, I expected that.
      Now, short R78 (10K) from pad to pad with a short piece of wire.
      Measure hum before and after shorting.
      radio 3fm heet het tegenwoordig en is er nog steeds
      Good !! I am listening it online.
      ????? For now leave the ICs as normal, just short R78.
      We are following a path here, testing step by step.
      Looks long, but is the shortest.
      • #33
        ok the fet bias are 5.40 volt from O to fet bias G
        R78 10k short piece of wire from pad to pad no difference
        ok de fet bias is 5.40 volt van 0 naar G van fet
        R78 10k een draadje tussen de weerstand geen verschil te horen en zien
        • #34
          the amplifier works now thanks for the info
