PV Session 400
  • #16
    Thank you Bill.
    22 ohm, not 22K, sorry.
    I will lift one side when I replace the open cap.
    I appreciate the additional info on measuring B-E voltage. Between you guys, I am getting a better understanding. I will also test across the legs as Enzo suggested.
    Soon as I get a second, I will test the Xstrs correctly. It may be tomorrow evening before I get a chance.
    Thank you.
    Justin
    • #17
      Thanks Enzo.
      I figured the value was ok, I just need to know if the non polarized film cap I have on hand is ok to substitute the open electrolytic.
      The 22 ohm resistor that measured "closed" is the one that hooks to one leg of the open cap. I will pull one end and test it as well as give the driver another look.
      I will update soon as I make more progress.
      Thanks.
      • #18
        Would someone be so kind as to repost the schematic from the first post? Seems to be a dead link. If not, I will call Peavey on Monday and post it here.
        • #19
          Here you go: Session 400_LTD.zip
          • #20
            Thank you!
