Does anybody know how to bypass the foot switch, and turn off the overdrive? My amp is stuck on overdrive, thereby not allowing me to use the clean channel for softer songs. I've tried different foot switches, so it's not the switch itself. Any suggestions? Thanks.
Fender M-80 Chorus 212 - overdrive versus clean channel
Putting aside the foot switch for a moment... Does the clean/OD switch on the actual amp not function and all you get is distortion? I just was not sure if you have clean at all or only in reference to when you try the foot switch. I believe the channel switch on the amp needs to be pushed in(OD setting) to get the foot switch to function. Just need more detailed information...
This a link to the schematic on the site and thanks to Jazz P Bass for the post...
http://music-electronics-forum.com/a...-80-chorus.pdfWhen the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostPutting aside the foot switch for a moment... Does the clean/OD switch on the actual amp not function and all you get is distortion?
Originally posted by DrGonz78 View PostI just was not sure if you have clean at all or only in reference to when you try the foot switch. I believe the channel switch on the amp needs to be pushed in(OD setting) to get the foot switch to function. Just need more detailed information...
THANK YOU!
