Hi all,
I have an SWR LA15 here with a severe case of "DC outputting". I have 55.6V on the main output (+ rail is 57V). After reading all previous posts on the LA15 subject and checking all active components and changing a few suspect caps, I have had no success whatsoever. So I decided to change all transistors out of desperation, as well as the bridge rectifier and D4 (the schematic is elsewhere on this forum).
The bias pot has no effect and C8 has blown up due to a too high voltage on its pins (that has already happened to someone in one previous post)
The - rail is only 46V when measured with a DMM and it looks like this on the scope:
![Click image for larger version
Again, the ouptut is at 55.6V, and it also does look a lot like what you see on the scope screen.
Any help would be greatly appreciated!
