Bugs in a scratch built JTM45
  • Bugs in a scratch built JTM45
    Just got this puppy finished up tonight and I'm having trouble with loud noise [with all the levels at zero and no guitar input] and once it warms up it's popping fuses.
    Transformers: HY022798 PT, WOT45LHR OT, W022699
    Tubes: (all brand new) 3 12ax7's, 2 KT66's, 1 5AR4
    Schem followed (except bias supply) : http://www.amparchives.com/Amp%20Arc...5-readable.jpg
    Bias supply used: http://taweber.powweb.com/store/6m45_layout.jpg
    Unit makes loud noise with v3 installed. No noise without v3. Isolated problem to the position, not the tube itself. Blowing mains after a minute or so. B+ fuse is intact.
    This is all I could get before it ran me out of fuses.
    V3
    1. 399.5
    2. .049
    3. .002
    6. 398.2
    I didn't write it down but high voltage at the 5AR4 was a little over 450
    It may have been a bad quick read but it looked like a -3.xxV bias voltage ???
    Any thoughts on where/how to hunt for the bug, or any other info I can provide, until I can reload on fuses?
    Thanks, as always.
    ~Semi-No0b Hobbyist~
    I like to fire a new amp up with a dim bulb tester, or current reading variac.
    It saves lots of fuses, if you have problems.
    With the dim bulb I start with the tubes out.
    If no bright lights or problems, then put tubes in.
    Then without the dim bulb, with fuses.
    Make sure you have enogh negative bias voltage.
    https://encrypted-tbn0.gstatic.com/i...iZS3o54SdhewqA
    Terry
      +1 on the bulb tester. Build that while waiting, maybe? If you have the parts lying around.
      Go over that bias supply again & again til you get more fuses. Look for mismarked resistors & check values - mistakes have been made matking them. R.G. Keen's got fuse debugging on his tube amp debugging page. Give it all a read and apply it when you get more fuses. Check the bias voltage with the power tubes out - what do you get raw with no tubes?
      Also, doesn't seem like V3 is conducting? Should be more volts on that cathode, no?
      Describe the noise, too - hum, buzz, screech, other-wordly?
      Justin
        The noise was full on hum with v3 in. BBBBBBBRRRRRRRRRRR
        This is the first occasion that I've needed a limiter, so will be putting one together asap. Might have a variac on the way too...
        Every part was checked with a meter before going in. Will check over bias circuit again for sure.
          Here is the link to the Metro Site.
          There you can download the full instruction manual for a JTM45.
          It has a power up section and lists the voltages.
          Jtm 45 kit instructions - MetroAmp Wiki
          Terry
              So it only buzzes with V3 installed? Does it no longer blow fuses with V3 out?
              Yes, please do make a light bulb limiter and use it.
              Since V3 won't conduct, and you are blowing the mains fuse rather than the high voltage fuse, it leads me to think your problem might be on the heater wiring to that socket. Just a thought. Or one of the sockets.
              Does it make a difference if you leave the standby switch off?
              If none of that helps, my first option would be to power it up with no tubes at all. Verify you have 6vAC between the appropriate pins of each socket and not on the others. I'd then install the rectifier only, and fire it up, and turn the standby on. So it is ready to play except for missing the tubes. I'd verify I have B+ at pins 3 and 4 of each power tube, and improtant that we have reasonable bias voltage at pins 5. Missing bias voltage is a problem, but if the power stage had such issues, it wouldn;t care if V3 was gone.
              In the photo, far right, is that cathode bypass cap wired backwards? At the left end of the board, what looks like a bias supply has a blue cap that looks right. The black cap below it is wired the other way. If that cap is for the negative bias supply, it is backwards. If it is something else, I can;t tell from here.
              In general, the small tubes used in the preamp and phase inverter don't usually have a way to blow fuses. They are connected to the B+ through high value resistors that limit current, or even the one CF triode would have a hard time of that. Any miswired socket could do a lot of things. I have seen carefully wired nice looking work on sockets except that it was all of one pin from where it should be.
              My concern is that you have discovered that pulling V3 kills the noise, but blowing fuses is a bigger issue, and V3 may just be passing along noises that are a result of the main issue. See if it will hold a fuse (or not light the bulb) with all the tubes gone, then with ONLY the rectifier, then with just the recto and the two power tubes.
                Regarding the "BRRRRRRRR" with V3 installed, try temporarily disconnecting the NFB loop, you may have the OT primary wires the wrong way around?
                As Enzo says, when powering up with no power tubes installed check for at least -55vdc (-60vdc if you can swing that far) at pin 5 of the power tube sockets, this way you will have the plate current set to the cool side.
                I'd remount the PI & preamp filters on the board, grounded away from the main & screen supply caps - this may alleviate some hum, but is not related to your blown fuses.
                  Just on a general note, regarding the bias adjuster, it's not good practice to use a (panel mount type) pot's terminals to physically mount / secure it; better to use a trimmer there.
                  Pete
                    Just checking in from my phone, thanks for the input guys.
                    And yep, I guess I did install that cap on the right backwards. I cant hardly believe I missed that.
                    And the black cap under the bias supply is a filter coming off of the choke and first filter bank. It's layed out as shown in the weber layout.
                    Yes, the fuse still blows with v3 out, not sure about with only recto and/or power tubes or with standby off.
                    I will follow all the advice given and provide data at the first opportunity I have, probably today.
                      If that cap was installed backwards, consider it toast.
                      Install a new one.
                        Ok, I was able to come home for lunch today and get a few readings. All looks normal thus far.
                        With the limiter in place, and no tubes:
                        heaters all 6.47
                        V6
                        P6 - 369.2
                        P4 - 369.5
                        P8 - 82.3
                        P2 - 84.8
                        With Rectifier in:
                        --- slight momentary burst of light on limiter when mains powered on, bigger burst of momentary light when standby engaged. Did not repeat when switched off and back on again.
                        V5
                        P3 - 494
                        P4 - 494
                        P5 - -37.67
                        V4
                        P3 - 494
                        P4 - 494
                        P5 - -37.62
                        I did go ahead and flip the cap around, will replace later. Also found an unsoldered eyelet at the diode/resister joint and soldered it. That's as far as I could get for right now. Gotta get back to work now....
                          When you get time, see if you can adjust and get higher bias negantive voltage.
                          The Bias is what keeps the power tubes from run away, and pulling so much current.
                          With the tubes out and the pot at max, I would think you could get at least -50v.
                          Your -37v is low for under load conditions, I bet it will drop even lower with the tubes in, and with it off standby.
                          Terry
                            V6 pins 2 & 8 - Are these AC or dc? Either way, they don't look right.
                            As Big Teee says, -37vdc on the power tube grids is most likely why your fuse is blowing, your amp is biased way hot.
                              Back home from work. Gotta love it..
                              Pins 2 & 8 of V6 are 82/84 vac each(post to ground) , a little lower with the recto in. And 4.99 vac between pins.
                              Best I can get on the bias is -38 vdc, and that's with the pot wide open. It will dial all the way down to -19.1. That's the range.
                              I have 50.0 vac out of the PT tap, -45.3 vdc after the diode, -38.9 vdc after the 10k resistor, and -37.9 after the 220k resistors, respectively.
                              How do I get the bias up?
