Looking a little more, I'm hoping the low bias voltage isn't just because you are on the limiter bulb.
I did something stupid to my JTM45 build
Originally posted by g-one View PostLooking a little more, I'm hoping the low bias voltage isn't just because you are on the limiter bulb.~Semi-No0b Hobbyist~
Originally posted by g-one View PostSo is there -31 at the 15K but -25 at the actual grids?
It's getting late and I'm getting a little frustrated. Better get on it with a fresh head tomorrow....~Semi-No0b Hobbyist~
Grid voltages on preamp tubes can be difficult to measure with respect to ground. The best way is to measure from cathode to grid and do the math.
Yours seem ok. I'm pretty sure if you remove V3 only you will still have the problem with the bulb lighting up.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
When you get back into it, I would suggest you try removing the power tubes and the bulb limiter. If it doesn't blow the fuse when you come out of standby (with no power tubes), you can be fairly sure the problem is the bias circuit (or power tubes).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
One last question before logging off...
Is there anything that can be damaged by P3 of the V1 tube being open or highly resistive and being powered on? Is there some capacitor somewhere that can be easily fried by this scenario?~Semi-No0b Hobbyist~
Originally posted by g-one View PostWhen you get back into it, I would suggest you try removing the power tubes and the bulb limiter. If it doesn't blow the fuse when you come out of standby (with no power tubes), you can be fairly sure the problem is the bias circuit (or power tubes).
The fuse does not blow with the power tubes removed and all other tubes in.
It also does not blow with the preamp tubes removed and all the other tubes in.~Semi-No0b Hobbyist~
Like Jazz said, nothing will be damaged from pin3 of V1 being open.
Originally posted by mort View PostThe fuse does not blow with the power tubes removed and all other tubes in.
What wattage bulb is in your limiter?
I'm thinking maybe the original power tubes were the problem, and the bulb may be distracting us.
Were the new power tubes tried with the fuse (with all tubes in) or just with the limiter?
Edit: Just to check, you are using slow-blow fuses, and it is the mains fuse (2amp slow) that was blowing, is this correct?Last edited by g1; 08-04-2013, 04:42 AM.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Sort of off topic question here.. but I didn't realize it's okay to turn a tube amp on with no tubes installed.
There's no risk of damage to the output transformer in doing this for troubleshooting purposes?
I have a Marshall DSL-401 that blows the mains fuse immediately when powered on.. I wanted to try it with no tubes installed, but wasn't sure what the effect on the OT would be.
No the output transformer could care less.
The main item stressed is the capacitors as they really do want to see a loaded down power supply (ie: all of the tubes installed)
It is highly unlikely that the preamp section is blowing the fuse, so remove just the output tubes for the initial test.
It sounds almost like you should rebuild your bias supply completely, and possibly the wiring around the rectifier tube... Sometimes rebuilding whole things, even if you don't know that's the problem, just fixes it and makes it easy. + you get back to playing faster. ;-)
