Hello all, first post here. I need some advice on troubleshooting a metro kit JTM45 amplifier which has one tube (V1) which intermittently redplates. The amp sounds great when it is working. Sometimes I can play it for 3 weeks with no problem, then it redplates, then maybe it will do it 2 days later then maybe again 2 weeks later. I know it isn't the tube because I've used 3 different tubes (KT66) and it only happens in the V4 socket. Had a tech check out the amp twice already and he is stumped. The tubes are biased correctly, the current and voltages in the amp are all correct and to make it worse it won't redplate ever when it is in the techs shop! The tech on the first visit added "swamp" resistors in series with pin 5 on each power tube and shortened some of the wire lengths, this removed a parasitic oscillation that he detected. The second time he moved the wires which go from pins 5 of the power tubes out from under the circuit board and sautered them on top because he thought maybe there had been a bad sauter joint underneath (see photo). Of course the amp worked and sounded great in his shop but weeks later I find it is still intermittently redplating.
I went through and checked all the capacitors and resistors with a multimeter and everything looked to be in spec. I also double checked all the solder joints and none look suspicious.
What could cause this to be happening? Could it be one of the coupling caps is leaky? Could it have something to do with the bias diode? Or should I suspect either the grid leak resistor or the grid stopper resistor on that valve?
Just looking for suggestions on how to proceed from here, any help appreciated. Attached is a metro JTM45 schematic for reference.
