musicman amps layouts?
  • musicman amps layouts?
    i am experimenting with ss preamp amps...does any body knows where to get the musicman amps layouts (HD 130)...schematics are an easy find...but i don't see layouts.
    thanks for any help
    I do not recall ever seeing an MM Layout.
    Consider yourself lucky when one is available. (Fender & Peavey come to mind)
    There are often repairs where I have to make a layout.
    To the circuit being worked on, mind you.
      Here's one for the RD50 that Enzo had posted. Not sure if he has others or not.
      Musicman RD50a layout 2.PDF
        I stand corrected.
          I must admit I had never seen that either. Do you mind Enzo if I pass that on to the guys over AT the Music Man forum?
            ANything posted here is up for the public to see, share as you see fit.
