Here is some updates on Orange Tiny Terror. If you need any parts or service info, I will try to help you along...
Oh man, this amp shreds. Sounds killer. I would buy or build one for myself. Made in PRC (That's Taiwan). Much better sound and construction than a typical Mainland Chinese Amp. Better support also I would say.
However, as you know (or just discovered), the stock ORANGE UK speaker cable has defective plugs, which will blow the transformers.
1. Never operate the amp without a speaker plugged in. This will damage the amp.
2. Never plug / unplug the speaker cable with the power turned on. This can damage the amp.
3. If the fuse blows, find and correct the problem FIRST, before operating the amp again.
4. Fuses do not just blow for no reason. If the fuse blows, there is a serious problem. Do not continue to use the amp if the fuse is blowing.
Orange Factory Stock Speaker Cable: It's defective, don't use it.
Buy a good speaker cable. Make sure it has Switchcraft or Neutrik Plugs installed.
Be very wary, and cautious of fake knockoff plugs. These plugs are made to look like the real Switchcraft ones, but they are fakes.
The fake junk plugs will destroy the transformers, sockets and tubes. It will cost plenty $$$ to repair this damage.
Good speaker cables, with Switchcraft or Neutrik plugs, won't cost a lot.
It is unnecessary to spend a lot of money on a speaker cable. You can buy a good one for about $6.
Monster Cable: It's a waste of money. Don't even bother.
Hot Wires Speaker Cables: Defective Plugs, as described above. Don't buy or use these cables.
Cables with "lifetime Warrantee:" Just because it has a warrantee -- does not mean it's a good cable.
The warrantee does not cover damage to your amplifier, caused by junk defect plugs. BEWARE of this scam and don't fall for it!
