View Post
See what all those speed reading classes do to you?
@OP: Sure. You can do it. The sag for both elements paralleled will be less than the sag in a CT configuration. Using only one anode you'll have to be careful to limit the currents and first filter cap to not damage the cathodes with too much current in the charging pulses.
A resistor to fake the sag is a viable alternative and might be an easier solution in the face of needing heater power for a tube.
