Hi again Alga,
I've took the same road several years ago... the HRD is probably the amp that I've modified the most - with a variable success and less rewards than with my other amps, sadly and FWIW.
Mine currently includes three additional switches and a new "variable NFB" pot on the back pannel... I'll share with you a depiction of the related mods ASAP.
Regarding the BassMan voicing, I've tweaked the drive channel in a way that I find satisfying and that I'll explain you later.
Regarding the clean channel, I'm still not totally satisfied but I've found that [a resistor (ideally a trim pot) in series with a cap] parallel to R9 is a good way to "tune" the tone. It's even possible to implement a "contour" control there. Again, more later about that.
Now, I'd find difficult to recommend a mod as a first step: if you "blackface" the tone stack without altering the rest of the circuit, you might find the clean channel too dark and thumpy... if you do a second mod to correct that, the "honk" might come back...
A problem with this amp is that its stock EQ has been designed to match the Tweed style 1x12 cab and its resonance: even if the circuit is tweaked to approximate a Blackface, it won't sound like an open 1x12 or 2x12...
Here is the frequency response of my uber-modified HRD upon the curve of a "real" Fender Twin Reverb RI: this time, the frequency response has been captured through a direct box between power amp and cab:
BTW, the green and pink lines under the frequency response translate the distortion generated: it's something to keep in mind, since a same EQing with a different distortion curve doesn't sound the same at all.
In this case, the HRD distorts less because I've fitted it with a 12AY7 in V1 (the Twin has still its stock 12AX7's). But the result is similar.
In fact, these curves are close enough to make my HRD "Twin" sounding... but only through the cab of the Twin. Once played through its own cab, it returns to its HRD sonic footprint...
Now, it's true that with lits imited value, size & weight + its solid 40w of power, the HRD remains a good amp for live sessions - reasons why I often take mine on stage.
Hope to be useful. See you later!
