Hello all
I'm new here so salutations and Merry Christmas where applicable!
My question is regarding rectifiers
I've built one vibrolux head (5F11) and really quite like it . It was my first entire emp build. using an existing 50s homebuilt PA chassis with accompanying nice Hammond transformers), Originally I built it as a tweed deluxe but wasn't keen on it so I switched it to a vibrolux but added a negative feedback switch for fun.
I want to build another and have a nice stereo pair!
I have another bit of chassis with all the right sockets (3 large octal 2 small 9 pin)that has a usable power transformer but with a 6X5 rectifier, I also have a push pull 6V6 transformer from an organ.
So I have most of the bits
I've read not so great things about the 6X5. Can I use a 5Y3 instead if do some fiddling with the power coming from the transformer(for the rectifier filaments)? I know the 5Y3 normally has it's own filament power supply separate from the 12AX7 and 6V6 heaters)
On this amp as it currently is (before I gut it) it uses the same heaters for everything
Thanks
Thanks
