I was using the Marshall JCM900 Dual Reverb to drive 60Hz to break in the speaker, it blew the fuse again.
Before all these, the amp blew fuse, I change the fuse and tested ok. But I did not see one of the tube is blown. Today when I tried to see the output to 12V into a 8ohm speaker, I couldn't get there. So I start troubleshoot and found the left 6L6 had power in it and not lighting up. So I just change to another tube and it worked.
I got it to 12Vrms and ran for over an hour. I went to snooze and when I wake up, the amp was dead. The fuse blown and after I change the fuse, I couldn't get 12V again. I looked, the new tube blown also. So this is no longer coincident anymore.
Any suggestion what to look for. I did check all the voltage a month ago before replacing the fuse. What can make the tube blow. It is the same left tube that blown. Obviously I did not troubleshoot yet, but it's strange only one tube blown. And it will work for at least an hour before the new tube blown.
