Originally posted by xjbear
View Post
Can someone ID what that bias wind CT transistor circuit is doing?
In every example I can find -55V should be fine for 6550's at 500V with any reasonable load. Try the bias rite with only one tube to avoid any confusion and retest. Do this with two tubes in two separate tests. What current reading do you get?
EDIT: Looks like the circuit on the CT of the bias winding is just the power and standby indicator lamps. Looks like a PITA to retrofit all that windings circuitry. Please report on the bias current when you can.
