Fender Princeton Chorus blowing fuses
    Don't think I've ever posted it, but I will try again.
    edit: whaddya know, it worked when I cropped it like g-one suggested.
      This is what it is supposed to look like. I had it hooked up wrong the first time.
        The picture nashvillebill posted was to show you how the mica spacers look between the output IC's and the heatsink.
        I have put yellow boxes around them, if you look real close you can see the spacers. You need to determine that both your output IC's have spacers when they are mounted to the heatsink.
