Originally posted by catstrat
View Post
Output transistors Q203, Q207, Q209 and Q211 are wired together. All of the Collectors are wired to each other, all of the Bases are wired together, and the Emitters are connected to each other through 0.22R resistors. If one of the transistors develops a short between any two of its' terminals, then the other transistors will also show as shorted across those same two terminals. If you remove the transistor with the short, the other transistors will now test as okay unless they re shorted as well.
If the other transistors tested as okay in circuit, but then test as shorted when removed from circuit, then either you misread the test in circuit or you damaged them when removing them or I suppose that you could also be misreading the out of circuit test. For me it would help to know what terminals on the transistors are showing as shorted, what meter setting you are using and what readings you are getting.
