I am new to this forum and a little new to tubes.
I just picked-up a Bogen K15. And wanted to get your folks thoughts.
It's a cathode biased 6L6PP with 12AX7/6AV6 pre and a 12AX7 LTP. (Schematic attached)
This is only my second conversion and my first PP amp - so, I thought cathode biased was a good choice.
Here is my plan once I receive the amp:
1. Visually inspect for (a) anything burnt/leaking, (b) verify wiring versus schematic.
2. Bring up on variac/dim bulb and check voltages v. schematic.
3. Anything funky, replace/repair. Maybe recap anyway.
4. Gut the mic transformer stuff and install 1/4 input jack. Install a speaker out jack.
5. See what it sounds like. Maybe change some of the values around the preamp tubes to be more traditional (68k input, 1M grid, 100k plate, 1k5 cathode) if it sounds bad.
Here are some initial questions since I am fairly new to this:
1. 300-0-300 secondaries seem kind of wimpy for 6L6, and the 6AX5 is a bit of an oddball recto (isn't it ?). So, do you guys see anything weird here? Anything you would change from the start? Otherwise, I was planning to leave any power section mods til last (like maybe setting up for 6V6s instead)
2. Any suggestions on the tone stack? Not very familiar with 2 knob ones. Maybe it'll work great??? dunno.
3. I know a 6AV6 is half of a 12AX7. Any value in changing sockets and installing a 12A_7 to give me another half a triode to play with? Maybe can have two channels each with a 12AX7 before PI. Or, cascade one channel thru? Or, cathode follower if tone stack sucks. Or, maybe leave the 6AV6 in there and set it up as a concertina to experiment with the sound of a LTP versus concertina (obviously not at the same time!). Or... what?
4. Any value in ditching the lower voltage B+ taps and only using the 300V for the entire preamp? What is the benefit of the original design where each previous stage gets less B+?
Anyway, what do you folks think are the potentials for this amp???
Rob
Rob
