Need some help for a puzzling issue on a newly built 5e9-a circuit
  • #16
    Leakage on the input many times is the result of low plate voltage. The temolo intensity problem also suggests a shift in B+. Might just be a difference in mains voltage. Does the pilot light seem dim?
    • #17
      Originally posted by loudthud View Post
      ... Does the pilot light seem dim?
      Isn't it a bias tremolo..?
      • #18
        Technically I would say yes. But not the power tube bias. It modulates voltage on the PI cathode.
        • #19
          Can someone enlighten me as to what this circuit is doing?!? (in yellow highlight) It looks problematic. I'd be inclined to remove that 10M resistor and see what happens. Maybe it was doing something when the chassis was only 0V and not earthed? Maybe the guy is using some kind of power conditioner with the ground on a big capacitor or even a ground lift adapter. That could put DC right onto the chassis with this circuit depending on how the footswitch is grounded.
          • #20
            Huh, ops... True, I didn't pay close attention, the 10M resistor threw me off. Hm.. I don't get that one, what's the purpose of having it there?
            • #21
              It supplies the voltage that the LFOscillator requires to run.
              A bit of overkill coming off of the B+.
              But it is what it is.
              • #22
                I don't see how it's doing that.?. It's isolated from all B+ and bias circuits. The oscillator takes it's HV from the screen node. That's a 10M resistor from the final HV node to the footswitch jack circuit which terminates at the footswitch + lug between two caps in the phase shift circuit.
                • #23
                  I think Loudthud may have solved this puzzle (kickstarter)
                  See here there: http://music-electronics-forum.com/t38979/#post378068
                  • #24
                    I agree that this is a "kickstarter."
                    Note that, in the 5E9 circuit, the closed footswith turns the tremolo low frequency oscillator (LFO) OFF and the kickstarter voltage is positive.
                    In the blackface LFO the closed footswitch turns the tremolo LFO ON and the kickstarter voltage is negative being derived from the bias supply.
                    • #25
                      I just caught his addition to that thread. That must be it. I'd still remove it and see.
