Hi,
I recently removed the "death caps" on a Sunn Concert Bass amp. The amp powers up and functions; however, the pilot light on the AC switch stays on all the time, even in the off position.
I'm wondering what I did wrong, or if there is a way to get the light in the power switch to turn off when the switch is off.
Here is a description of the wiring:
The three wires go into the accessory outlet and from there:
green --> to ground on chassis.
Black --> circuit breaker --> thermal cutoff (located on the heatsink) --> to middle tab of AC switch
Black --> to the first side of the AC switch --> (second side of switch) primary wire to transformer
White --> Primary wire to transformer
Thanks.
Thanks.
