Fender Stage 160 hum
  • #31
    Hello to all,
    I've had one of these amps on the bench today with the same humm..after looking over the circuit it reminded me of a trace elliott amp. any how after checking the low voltage rails all is good there followed by signal tracing all good till the o/p stage. you got it name that loud hummm. so a main filter caps 3300uf x 2 with 4700uf x 2 and she's back in action.
    hope this helps out.
    cheers.
    Experience comes with more understanding
    • #32
      Originally posted by plec.22 View Post
      Hello to all,
      cheers.
      See post #1
      • #33
        It would seem post one still has faults with the amp. Some more voltages need checking out. Even look over oc tracks as been pointed out. The ht 45v +/- and +/-16 also 5 volts for the fx pcb.
