Hi Guys,
Fender rocpro1000. When switched on starts to crackle which clears within seconds. Every so often (2-3 times a minute) it cracks again. Sounds like static. Has had new power caps fitted some power resistors have also been replaced and have checked over the board and sorted out some dry joints which I believe are a common problem. There is also some 'scorching' to the board at the power resistors. I have removed the resistors, checked the board for fractures and resoldered the resistors back into place. Still the same 'static' crackle. This also comes through the reverb when turned up.
It is one of those noises, very annoying, but when you try and find it, yes, it hides !!! I know I am missing something relatively basic - but everytime I try to locate it, it disappears until it's all back together. I have tried with the board in, the board out etc etc but it still eludes me.
![Sad](https://music-electronics-forum.com/core/images/smilies/icon_sad.gif)
