I'm trying to repair this preamp without the schematic. Does anyone have it?
There's no sound at the output and I think it's a problem from the mute circuit. I'm not sure but while I was tracing the input signal I discovered that it disappears at the output of both master volumes (center taps). Then I lifted the wires from the center tap of the pots and voila, there it is the whole signal.
Is there any common part at the mute circuit that fails? I can't understand how it works and with no schem I don't know what to do. There are some transistors I see on the other schematics of Mesa circuits like 6426 and a lot J175 fets. By the way, standby switch is also part of the mute circuit.
I don't know if it's the same circuit or close but at the attached file you can see the mute circuit of the Lonestar.
Mesa Boogie Lonestar schematic.pdf
