Hello All:
I have two Peavey Bass Mark III amps that both had blown outputs.
One amps has the 400BH power board and the other has the 400BG power board.
The 400BH board also had 2 broken fuse holders on the board which were replaced as well.
I changed the original power supply caps in both amps (5000uf and the 1000uf caps) due to age.
I replaced the blown outputs and fired them up into a JBL 18 inch subwoofer.
They both are quiet and work fine but the clip light seems to be hyper active.
With the pre and post volumes at 11:00 o'clock, the clip indicator light seems to
illuminate very frequently. I was playing a fender strat with humbuckers to test the
amps. No pedals or boost was used, just the guitar straight into the amp.
I was just testing the amp out; checking the bi-amp function, line out, etc.
Both amps are loud and there is no audible signs of clipping.
The hyperactive clipping is common to both amps.
Is this common for these amps?
