Hi
I'm new to this forum and also quite new to Tube amps, i have my BJ3 about a year now. I never had a problem with it but I haven't used it for a few weeks and when i plugged it in yesterday its got a very ugly buzzing/crackling noise. I haven't replaced any of the tubes yet but i did swap them around, V1 for V3 etc, it doesn't make a difference. I'm gonna try replacing all the tubes tonight but just thought I'd put up a post here and see if anyone had any advice first.
Heres a few observations I've made on the problem.
1. The buzzing really only kicks in once i insert a jack, its doesn't matter if the Jack is connected to a guitar or not though obviously it changes the nature of the buzzing if it does.
2. When i hold the guitar the buzzing is much worse than if its on the stand.
3. When i play the buzzing goes away
4. With the volume and master down the buzzing goes away and it really only kicks in when turned up to 4/5 or beyond.
5. Turning down the Treble to zero almost completely eradicates the buzzing even at full volume, turning down the Mid reduces it and turning down the Bass or Reverb has no effect
6. Its slightly worse with Fat on.
7. My guitar probably needs the pots and jack input cleaned as fiddling with these can have an effect on the buzzing but i don't think this is the problem as the same buzzing is there when i tried a keyboard through the amp.
Any advice would be great guys cheers
