Originally posted by Leo_Gnardo
View Post
question about power rating on a potentiometer
~Semi-No0b Hobbyist~
Originally posted by mort View PostHmmm.. I'll take all of this into consideration. Mounting a power switch somewhere else isn't an issue, but the control will need to be readily accessible to the user. I suppose I could cut out a small square area of the chassis where the pot is going and put in a small piece of plexi and mount the pot to that. That would at least get it off of the chassis.This isn't the future I signed up for.
I never found a kit. Just sourced the parts and built them onto the main eyelet board. Was planning to mount the FET to the chassis wall and put some heat grease in between, as per the advice of the guy that did the schematic. But if you're saying that the heat sink needs to be isolated then maybe I need to rethink more than I thought.~Semi-No0b Hobbyist~
Originally posted by mort View PostI never found a kit. Just sourced the parts and built them onto the main eyelet board. Was planning to mount the FET to the chassis wall and put some heat grease in between, as per the advice of the guy that did the schematic. But if you're saying that the heat sink needs to be isolated then maybe I need to rethink more than I thought.
FWIW I remember some experimenters using LM317 regulators for hi voltage reg supplies in hi fi home builds 1980's, they were having problems similar if they didn't dope out the hazards first. (Audio Amateur magazine.)This isn't the future I signed up for.
I agree with ditch the switch on the pot.
Also note that a linear taper is specified on the schematic.
If it was my build I would just use a high quality pot such as http://media.digikey.com/pdf/Data%20...tyle%20RV4.pdf
See the spec section that lists 900V Dielectric strength and 500V operating voltage. That's the pertinent spec for your application. The 2W power rating is just along for the ride.
Proper parts selection is just plane old good engineering. Why try to make a silk purse out of a sow's ear?
They are available from Digikey at RV4NAYSD105A Precision Electronics Corporation | Potentiometers, Variable Resistors | DigiKey
Also remember that the pot body and shaft will be grounded to the earthed chassis.
P(ower)=V^2 (V squared)/R so admissible V is:
V=(Square root of) (P*R) = Sqrt (0.25W*1000000)=Sqrt 250000=500V
So with 500V applied, end to end, full track will dissipate rated 250mW .
Since Fet gate does not take current, things stay as calculated above.
As of:
Always fun times when Juan uses Mega-Font and his nuke-bomb picture...
Justin
Still applies to amps with 250VDC at the output:
don't like to post gory pictures though, so won't show the CSI forensic pictures of the unlucky singer who was standing just in front of those speakers, when voice coils were shot forward at 1250 fps (.44 Magnum speeds)
Just google "rail gun" or "coil gun"Last edited by J M Fahey; 02-15-2016, 04:13 AM.Juan Manuel Fahey
Originally posted by Tom Phillips View PostThey are available from Digikey at RV4NAYSD105A Precision Electronics Corporation | Potentiometers, Variable Resistors | DigiKey
The transistor, metal tab on there, I wouldn't chassis mount. Isolated heat sink & I'm not the worlds best at figuring out which would be a good heat sink to buy. Another back of the envelope calculation says you'll have up to 40 watts of heat to dissipate. You can always score heavy duty ones cheap at surplus, or if you rip up a dead solid state amp for parts. Look for some phenolic standoff legs to mount it, not plastic/nylon as they might bend & melt with the heat. Digikey might have these, might as well look if you're going to buy the control pot there. Same with the hardware holding that transistor to heatsink, I'd just bolt it on there with a schmear of heatsink grease, no plastic parts as they may melt & who needs that.This isn't the future I signed up for.
Originally posted by J M Fahey View Postdon't like to post gory pictures though, so won't show the CSI forensic pictures of the unlucky singer who was standing just in front of those speakers, when voice coils were shot forward at 1250 fps (.44 Magnum speeds)This isn't the future I signed up for.
No, it's a Crat-
(Ducks, runs out of room, as Juan throws charged lytics and a blown OT at me)
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Justin
Unjustly despised by armchair Guitar Gods by the way ..... or Harmony Central/My Les Paul/etc. guys, which are the same.
The best and most complex SS distortion I ever saw (although the original one was invented by Carvin's Murphy something).
And the Bass amps are straight Ampegs (same thing under the hood, different label and Tolex).
Maybe you were thinking about something guru human?Juan Manuel Fahey
My first amp (I don't count the Gorilla!) was a GX-30M. Got it in 1993. It's still working just fine, after I sold it to my aunt about 10 years ago. And it still sounds good! Not as good as my Concert, but seriously, is that a fair comparison?
And yes, I was poking the bear...
Re: Ampeg bass amps, I liked the oldies, before the proliferation of 5-strings and the pervasiveness of what I call "Rap Bass." And they still get mopped up by my 50W Bassman with periods-correct 2x15." You know, from when bass was an INSTRUMENT and not just a set of frequencies that are faked, processed, and overdone. And I will STILL put a real SVT up against anything. We need to be going in the opposite direction, instead of kilowatt power and inefficiency.
Originally posted by mort View Post...Was planning to mount the FET to the chassis wall and put some heat grease in between, as per the advice of the guy that did the schematic. But if you're saying that the heat sink needs to be isolated then maybe I need to rethink more than I thought.
Cheers,
Tom
I use an Aavid 43-77-20G pad between power MOSFET's and whatever they are mounted to. These pads will fit devices much larger than an IRF830, but they will work fine with the IRF830 and bigger is better, right?
I wouldn't isolate a heatsink and bolt directly to it because somewhere, sometime somebody will touch the thing not suspecting that it has the full B+ voltage on it. I would suggest drilling a hole through the center of a Wakefield 558-75AB heatsink and mount that on the outside of the chassis with the MOSFET on the inside of the chassis bolted through that hole in the heatsink and using the Aavid pad.
From the looks of the datasheet, I would say that the IRF830 is going to get real hot. If it burns up, you could use a STW12NK90Z which will definitely hold it and should only need the chassis as a heatsink. It also has zeners built into it so you don't need that external one. A 7721-7PPSG shoulder washer makes the mounting pretty slick.
