Randall rg100 Es ?
  • #46
    Last i heard they still do. That is my all time favorite thing Peavey ever did.
    • #47
      I went about and ordered a bunch of TL604cp chips months and months ago. Still got to test them to see if they are even legit, but I did not pay very much for them either. This thread just reminded me I have to build a test set up to check them out.
      Here is some info on the Peavey kits.
      https://www.tubesandmore.com/products/P-QTL604-AK
      • #48
        TL604 can still be purchased on ebay - $5.17
        Mark
        • #49
          Just for the record, if the original and replacement disappear, you can always kludge a replacement out of a generic CD4016/4066/whatever_it's_called_now .
          Gloriously crude, just 4 separate SPST gates , no extra circuitry to "help" you, no level shifting, no "enable" pin, no internal Logic, nothing.
          *You* supply the trigger voltages and maybe add a transistor and a couple resistors to invert signals so when one gate goes ON another goes OFF.
          In fact the functionality of I*two* TL604 in a single outdated 16 pin through hole package
          Larger than the original so no straight plug-in as the elegant Peavey replacement, but you can make a still small pcb hooked to original holes with some solid core wire to hold it safely.
          A drop of hot glue can help
          The point is that maybe someday no replacement or NOS is available, yet somehow these amps can still be made to work.
          On a personal side, TL604 is unobtanium, freight and Customs make them way more expensive than they are worth, so ironing and etching a small PCB becomes interesting.
          FWIW I have replaced them with a pair hard wired FETs, an N channel and a P channel with gates joined, a positive voltage turns one ON, the other OFF; a negative one does the exact opposite, works like a charm.
          Exact configuration depends on amp (GK/Fender/Peavey) because not all wire or trigger them the same way so the basic idea must be adapted to the particular amp.
          • #50
            From what I can see, the ones on ebay are coming from Hong Kong. I expect that they are counterfeit.
            • #51
              Just quoting myself to address whether or not these chips I ordered were real or fake... The verdict is in and ALL 12 of the chips passed with flying colors!! Holy Chip!! I was expecting the worst and that every one of them were worthless junk. So I paid 50 cents for each and I ordered 12. $8.20 total shipped for these rare birds!! I ordered them from UTSource direct on their website and not through Ebay, but probably would not have made any difference. I guess I took a gamble and won.
              • #52
                Not the same and you ordered from the "good" place.
                UTSource is "a Company" and presumed to stand behind their products; generic "Hong Kong EBay seller" MAY be a parking lot assistant guy or similar low pay jobber who at night earns a few extra bucks by reselling junk to unsuspecting Americans and who couldn´t care less about bad feedback, worst case he opens a new account and starts clean and fresh.
                Glad you got the good ones
                • #53
                  I meant I could have ordered from UTSource's Ebay page. If you look it up it has all the same logo stuff and is the same affiliation.
                  casibom< giriş/a> betturkey
