When you fix an amp it's good to understand its schematic. And understand how the amp works. In your case you need to understand at least the power supply in this amp:
- the power amp is supplied with +48V,
- then you have R44 resistor and D2 diode (this is most probably 27V Zener diode) - they provide voltage for the preamp,
- +27V supplies IC1 and IC3,
- R20 and R14 resistors form a "virtual ground" for IC1 and IC3 (they call it "COMMON BIAS LINE" on the schematic) and this virtual ground voltage is 13,5V (half of 27V),
- on inputs 2 and 3 of the IC1 you should have 13,5V (on the output - pin 6 there should be also 13,5V),
- pins 1 and 8 are not used in this amp so there is no point listing them.
As you can easily see, almost all voltages on IC1 are incorrect - starting from +27V power supply. It means that, most probably, there is a problem with D2 Zener diode. Also there is a problem with "virtual ground" divider - R20 and R14 resistors.
This is how I see it - I assume that the measurements that you made are correct.
Please fix the problems with DC voltages and then you may start looking for the signal. Check D2 diode and R14, R20 resistors.
Mark
Mark
