Has anyone had problems with new electro harmonix 12AT7's going bad, in the reverb driver position in Fender Deluxe AB763 or clones?
Nick did some great research about high plate voltage (and a lot of other stuff I don't understand) in the cathode follower spot in certain Marshall amps. I didn't understand the whole topic, but it sounded like the plate voltage or plate to heater difference was too large. in these amps, the reverb plate has 410 or higher on the plate.
The data sheet says not more than 300v plate, and not more than 100v heater to cathode.
Had my amp running great for a few days, the reverb started crackling and popping badly. Pull the reverb driver tube, goes away. Can't see well into the tube due to the socket rings that hold the aluminum guards on.
