I've swapped out the el84 for another and some of the noise has gone - I uncoupled the negative feedback resistor and it was slightly harsher and brighter so I put it back. The same problem remains however that if I turn it above 2, it's breaking up into a horrible brittle distortion. I'll try some of the above suggestions tomorrow - maybe the 5F2A circuit and the 190-0-190 80mA transformer that I'm using just aren't suited to an EL84?
Adapted 5F2A with EZ80 and EL84
Your heater voltage is holding up? I'm only asking because this rectifier runs on 6.3V heater.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
You're only biased at 7W idling (total dissipation***) with 221 working volts on the plate. You should be entirely safe reducing the cathode resistance to get closer to center bias. Try a 100R cathode. Maybe even lower. Ideal would be about 12w or 13W at idle. Maybe even 14W because the bias does get colder as the tube conducts signal. There are even market examples of amps running the el84/s at that level with higher plate voltage. ***One thing to consider is that the 11W max plate dissipation doesn't include the screen dissipation, which is part of the total tube dissipation as measured at the cathode resistor. Right now you're at 7W. That means something more like 5.5W or at most 6W of plate dissipation for a class A amp that should be at 100% plate dissipation for center bias.
I'd try a 100r cathode resistor and remeasure. You may even need to go lower."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostRight now you're at 7W. That means something more like 5.5W or at most 6W of plate dissipation for a class A amp that should be at 100% plate dissipation for center bias.
SE class A amps are usually designed to run centre biased at the rated Pd max of the tube for maximum power output but the don't have to be, they could be designed to be centre biased at a lower dissipation for longer tube life.
Originally posted by Dave H View PostChuck, With the plate voltage and OT impedance it has I don't think it can be centre biased at 100% plate dissipation. It's close to centre bias now at 7W, 30mA on the 5k tap. It would need a lower impedance OT to be centre biased at 100%. Having said that it's a guitar amp, it doesn't have to be centre biased. If it sounds better with a lower cathode resistor then go for it.
SE class A amps are usually designed to run centre biased at the rated Pd max of the tube for maximum power output but the don't have to be, they could be designed to be centre biased at a lower dissipation for longer tube life."Take two placebos, works twice as well." Enzo
Thanks for the expert advice everyone. It's much appreciated.
I'll get back on it next week when I have time, and report back - one change at a time to see what works - I'll measure the voltages at each stage:
1. OT back to the 5k tap from the 8k tap
2. lower the cathode resistor
3. Double up the feedback loop resistor
4. screen grid resistor
5. dropping HT with an extra filter stage (like AC4) - that one's a bit beyond my novice scope
Originally posted by stephenhartley View Post...5. dropping HT with an extra filter stage (like AC4) - that one's a bit beyond my novice scope
it does have quite a loud buzz which disappears when I plug the guitar in. I've spent a few hours today experimenting with different cathode and grid resistors and no matter what I try, I can't seem to get the dissipation wattage above 7. The battery on my multimeter went so it's time to give it a rest and have a fresh start.
I have two 60s SE EL84 amps - a Selmer little giant and a Broadway, both with awesome sound and I wanted to replicate that but keep the early Fender style build that I've used on my 20w & 30w builds - hence the rational of trying to adapt the 5F2A to an EZ80 and EL84.
Originally posted by stephenhartley View Postit does have quite a loud buzz which disappears when I plug the guitar in.
Originally posted by stephenhartley View PostI've spent a few hours today experimenting with different cathode and grid resistors and no matter what I try, I can't seem to get the dissipation wattage above 7.
Originally posted by stephenhartley View PostI wanted to replicate that but keep the early Fender style build that I've used on my 20w & 30w builds - hence the rational of trying to adapt the 5F2A to an EZ80 and EL84."Take two placebos, works twice as well." Enzo
Originally posted by Tom Phillips View PostI agree and my guess is that the sorting bar on the input jack is not grounded.
'Perhaps there's just too much drive voltage on the el84 grid'
The grid voltage has been measuring ~ 170v - how do I alter it?
Originally posted by stephenhartley View Post'Perhaps there's just too much drive voltage on the el84 grid'
It's the signal voltage on the control grid pin 2 that's too high.
If the amp vol is below 2 the tone control won't work very well which could be part of the problem. As a test try turning the guitar's vol pot down so the amp's vol pot can be set to 5 and still be clean then adjust the amp's tone pot as required. The amp tone pot will work better with its vol pot set to 5. If that sounds OK the gain of the amp could be reduced to make its vol/tone controls have a more useful range but it will never have much clean volume. I'd guess it's only about 2W because of the low B+Last edited by Dave H; 09-17-2018, 12:05 PM.
Originally posted by stephenhartley View PostBoth input sockets are grounded with their own wires to a dedicated ground along with the cathode resistor from the first half of the pre-amp tube...
