Another report on the CAD model...
Input signal taken to 100mV performance is excellent reaching maximum clean volume at 5 on all controls (roughly) and about 1V at the input of the PI. Like they were fashioning it after a phono amp or something.
The tone stack is a turd with poor independence between the controls, bands and huge losses.
Signal peaks do indeed clip in the preamp and this is preserved in the power amp at volume settings below about six (assuming a 20% audio taper). This may be where the ugly distortion is coming from, but I can't say for certain. I can say that if this is the case then there is no repair for the problem if the amp is left stock, BUT...
There's an easy fix. Most amps, for clean tones anyway, uber gain preamps not withstanding, always clip the power tubes first. This way maximum clean volume is achieved. With the volume control late in the preamp and the early preamp designed for such small signal sensitivity you could get some preamp clipping artifacts. and this amp IS NOT designed for good preamp clipping So...
Just move the volume control to right after the first triode like 99% of all other guitar amps (as well as the 6v6 yba2). You'll get roughly the same volume levels at volume control settings. But now the ugly preamp artifacts will be masked because the power tubes will be clipping well before it happens. As a bonus this mod should be more compatible with the front panel layout than the circuit that's in there now.
Here's a modified schematic:
