Try this setup vs. 3 series diodes in the normal configuration (just side by side strings) & you'll see what I mean. The harmonic content is at a higher frequency.
If someone is able to give me a technical explanation of what I have overlooked in this issue I will gladly admit I've been wrong, though.
The cunning thing of the JCM900 setup, though, is that the "bridge rectifier" allows getting rid of one diode, or, even better, more of them if you want to add more diodes into the string (anyone remember those LXH2 circuits). Say, a string of five series diodes will require only 7 diodes in bridge in oppose to 10 of the conventional configuration. I'm quite sure it saves some board space as well. However, at the point where I would find myself using more than five clipping diodes in a string I would likely start thinking about using some other methods of getting soft clipping.
