Hello. I have a new project p-p using el34 pentode mode. Plates 490V with 320V into the screens.
The screen grids are supplied by independent power supply and this makes the life very complicated from a safety point. I mean ramping the plate voltage always before screen grids. ( I had a fault happening with input signal applied when the mains dropped off and reconnected in seconds-the screen grids circuit blowed off ).
So I want to make the screen grids supply circuit dependent by the presence of the voltage at the plate.
Just for now I thinking at one simply solution but I don't see all aspects how reliable could be : I meant using a relay ( no more than 20-30mA ) controlled by plate voltage which comand dc contacts for screen circuit. I have no experiences with relays but I know the engaging voltage are related by an voltage ecart:- say using a 12V relay it have a minimum voltage to engage at 8.5V or so. For sure it exist a minimum voltage to disrupt: it is the same minimum voltage to engage ? How should I choose the relay for my application please ?
The relay solution is the fastest comes to my mind but I like to hear any practical solution I may use to avoid an accident using separate supplies for plate and screens please. Thanks.
The minimum operating voltage for relay is 70% by nominal, that corresponding to a 70 percent raport between plate and the screens which should ensure the screens will be engaged/disengaged at a point the plates voltage will be no less than the screens. Any cons please ? Thanks.
