Hi,
after (re)building a few SE (hifi) amps, I just finished building my first all tube
guitar amp. It has a JCM800-like pre-amp, 2 x 12AX7 followed by the EQ with some tweeks for frequency shifting with the mid controle.
Then a switchable fx-loop is inserted based on a single 12AU7, and this all works fine, actually I am really amazed about the result considering this is my first (serious) build.
Now the problem starts with the 2 x EL34 PP poweramp, (see schematic), for some reason its way to loud...... I know it sound strange as everything seems to work rather smoothly.
All voltage values are in line, no overheating, I did multiple checks on the lay-out and consequently the wiring, but once again, everything looks fine.
http://www.uploadarchief.net/files/download/pa3.jpg
http://www.uploadarchief.net/files/download/rt801-1.jpg
However, turning the master up say about 5 % makes my 4 x 12 inch goes
extremely loud, I mean in an unhealthy way.
I lowered the R value from the feedback circuit from 100K to 56K to 33K, in a desperate attempt to reduce the power.
I must be overlooking something here.
Any help, suggestions or feedback is more then welcome
Thanks in advance !
Thanks in advance !
