This is when I really wish I had a scope so I could see what's going on in there a little better. If I could isolate where the offending distortion is originating, then I could try to figure out how to tame the gain on that stage(s).
Tubeswell, your unit - does it overdrive at high dwell settings? Diablo, are you using a nice 12AT7 or a cheap one like me? I'm just wondering how much getting a better tube in there might help smooth some of that distortion out so it's not so offending - more overdrive rather than fuzz.
Mine sounds similar to what I've had in the past from cold bias situations (on power tubes), or even when I had a partially blown OT that plagued an amp build. Sounds raspy, grainy & unpleasant, but only with higher dwell & mostly on the attack.
