Hi,
I built a 300W 6xKT88 bass amp and everything works but I have some ground/hum issues with the preamp.
The power section is a copy of SVT2 Pro. The preamp is a mix of several other bass preamps. The amp looks like an SVT2 Pro - same transformer and tube placement but I have only 3 tubes in the preamp section.
The power amp by itslef is dead quiet. When the preamp is connected to it a hum appears which is not loud but is audible (if you play at loud volumes you won't notice it). Maybe as loud as fan's noise.
What's is strange (for me at least) is when I move around preamp's ground wire inside the chassis the hum level increases or decreases depending on the direction to which it is moved. There's only one path when the hum level picked up by the ground wire is at minimum but still audible.
If I short preamp's output to ground the hum is still there and as I said depends on wire position. Even if I short power amp's input to ground connecting the ground wire to PI ground introduces the hum in question. Master control (where the preamp "ends") doesn't affect hum level.
Initially I ran preamp's ground wire to it's corresponding cap ground on the PSU PCB but the hum there is much louder. Also tried different ground points only to confirm that minimum hum level is achieved if preamp's ground connects to PI ground and then only one path gives me the mimimum hum level.
What is strange also is hum level increases when I boost the 300Hz EQ band.
I would appreciate if anyone can comment on this issue.
