Vibroverb board
  • Vibroverb board
    Anybody know or can measure the dimensions (width and length) of a 6G16 vibroverb eyelet board?
    Thanks,
    David
    Maybe looking at descriptions on commercial sales sites for such boards looking for dimensions.?
      I haven't been able to find anyone selling the brown vibroverb board. I want to maybe build one into a head with the trannys and tubes standing up so I need to make a mirror image of the eyelet board. I have the Fender layout to go by but I'd like to know the approximate dimensions to get started with.
      Thanks,
      Daivd
        Is there any reason to think that Leo might have used a standard size board for amps of that relative size. For example, might it be a similar (overall) in size to later models such as a AA763?
        Maybe buying in bulk would have made sense at the time as it does today.
        Just speculation without doing any research...having said that...I am sure the exact dimension will be available from somewhere or someone.
        Just my 2 cents.
        Mandopicker
          Marsh Amps has them. No affiliation, just happened to know.
          MPM
            Interesting; I'm considering the exact same thing as I picked up suitable iron cheap. Have you found a suitable reverb tank that's designed to hang from the top rather than sit on the bottom? Look forward to your build.
              The tank I have has holes along the edge. I was going to put some rubber grommets in the holes and just loosely screw it to the top above the transformers or will it pick up hum sitting above them?
                The accutronics tanks are designed to be mounted a certain way. The 7th character in the tank code indicates the intended mounting position.
                A = horizontal,open side up
                B = horizontal, open side down
                C = vertical wall,long axis horizontal, connectors up
                D = vertical wall, long axis horizontal, connectors down
                E = vertical wall, long axis vertical, input up
                F = vertical wall, long axis vertical, output up
                Ideally, you'd use one with an "A" as the 7th character
                  Given the correct mount, you could probably get away with mounting above the transformers. I only say that because my Chieftain Reverb is quite tight also. Everything is in close proximity of each other. The metal tank on the reverb is essentially a shield. Success is probably more in the details of wiring with good cable, etc.
                  Black sheep, black sheep, you got some wool?
                  Ya, I do man. My back is full.
                    Hi dw
                    FWIW when I make my eyelet boards, I measure them to fit in the chassis I make, so that they are 'high' and 'long' enough to hold the type of components that need to go on there without cramping the chassis, if that is any help. I don't believe there is any need to make an exact facsimilie of the original, as long as it functions without unwanted hums etc.
