Hello!
The schematic is a Mesa Double Rec. (http://www.freeinfosociety.com/elect...iew.php?id=507)
So far I have two questions:
OT Impendance: If I have understanded correctly, then Raa should be 2.8kohm. It's quite hard to find such a transformer. Most 100W and 120W have a Raa = 1.9kohm.
PT power: How much should the coil for the anode voltage bear?
The datasheet says, that for two 6L6's in class AB1 tetrode with fixed bias and Vp= 450V(460V on the Mesa) the Ip max is 210mA. So for four tubes, that is 420mA + 40mA for the preamp tubes = 460mA. Seems a little bit high?
Thanks!
Thanks!
