Speaker Choice for 5F2a
  • Speaker Choice for 5F2a
    Hello everybody,
    I'm putting together a 5F2a Princeton Clone. The cabinet will be pine. I haven't quite decided on a 10 or 12 inch speaker. That's my first decision. After that, what is a versatile speaker to put into it? I'm looking for lots of clean headroom, something loud that can handle country to rock and roll.
    1. 10" or 12"
    2. Alnico/Ceramic, watt handling, etc.
    The ones that have caught my eye so far are the Ragun' Cajun, Eminence Patriot Cannabis Rex, and several Ted Weber speakers. Price point is $40-$70.
    Thanks,
    KB
    Hi KB
    Those emi speakers are all pretty powerfully rated compared to the 5-10W (max) of a 5F2A. I think it would sing better with a 15W speaker. Maybe go for one of the low-powered Weber's. JM2CW
      I should have mentioned, it has a 12 watt @ 8 ohm output transformer. Should I still go for a lower rated speaker or will a 50 watt be good too?
        Nah 15W would be about right. The OT rating affects how much/soon the OT saturates and how much bass it carries, but the overall power rating is affected by the tube type and the way it is biased. As a rough rule of thumb, amps with 1 x single-ended Class A biased tube don't put out more than about half the max. plate dissipation rating. The 6V6GT in a 5F2A is capable of about 4-5W. A SE 5881 might get you to 8W on a good day, and a SE KT88 might get you to 20W (if your B+ was high enough and your PT heater winding was up to it)
          Okay. Thanks. Good to know.
            What tubeswell said. I've got a nice example of a Princeton Tweed, a 1960. I tried the best Weber has, about $100 alnico 8", and a lower priced Weber 0too. On the advise of a lady on another forum I ended up with an 8" $18 Jensen MOD that smoked any other speaker in that particular amp. YMMV, but for under $20 what can you lose?
            Thermionic vacuum devices rule.
              How about an EVM12L?
                That's a speaker that will put out exactly what you put in, no coloration. Mine sounds pretty good with my 5E3. But it's a heavy, high power speaker and not one that you'd normally think about matching with a little guy like the 5F2A.
                That being said, it may be a match made in heaven! My EVM12L is in a small open back cab. I'll have to try that combination this weekend, and I'll report back.
                  That's sound I'm trying to achieve. I'm plugging in with an ES-335 style guitar that has remarkable overtones and resonance. I plan on using a tele in the future as well.
