Howdy,
I'm designing/building a 2xEL34, class AB, SS rectifier based amp and I'm trying to pick a power xformer, but I'm unsure about the current requirements. I'm considering using a Hammond 272FX with 300-0-300vac @ 150ma.
I figured the 272FX will put out around 430 plate volts and with 25w/EL34 dissipation: 25w/430v = 58ma per EL34. And including 4 12AX7 preamp tubes at 3ma/triode max => 24ma. So I've got max current draw at about 140ma: 2 x 58 + 24 = 140ma...
...but most of the schematics of similar amps I've seen use a 272HX (200ma) or even a 272JX (250ma). These seem like overkill, 150ma seems like enough - am I off here, what am I missing?
