I recently purchased two telefunken 8" speakers similar to the link below. They were advertised as 4 ohm but actually measure approx. 1.25 ohms. I realize the actual measurement is usually lower than 4, 8, 16 etc. but 1.25 from a 4 ohm? I hooked one up to a 4 ohm output on a 5F2-A build and it sounded O.K. I haven't built a cabinet for these yet so I just plugged it in sitting on top of the amp. No real dynamics, but I wanted to see if there was any real issues before remounting into something.
I have a couple of questions.
How critical is impedance? Is there a range that can be adequate without being on a gnats a**?
I was going to use these two in series (going by advertised rating) and paralleled with a Jensen or celestion 8 ohm to get a total of 4 ohms or these 3 in series (16 ohms) and parallel them with a celestion 16 ohm I have for a total of 8 ohms. I also considered that as low as the impedance is on these, can I just series them with an 8 ohm on an 8 ohm output ?
Does it make a difference if the speakers have different wattage ratings as long as I don't overpower the lowest rated speaker?
Are there any other issues I may have with any of these scenarios?
Thanks to all in advance for any help. I look forward to the day I can help in return.
Telefunken Fullrange AlNico Phenolic Spider Speaker - eBay (item 390142981821 end time Jan-20-10 09:55:58 PST)
