Transformer core orientation
  • Transformer core orientation
    Howdy,
    Normally with two vertical mounted transformers you orient the core of the PT 90 degrees to the core of the OT. In the case of my current build, my PT is horizontal mount. What is the best way to orient the cores of these two transformers to reduce interference and hum? They are being mounted to a small chassis, so orientation is a factor. Thanks for any help.
    Thanks,
    Steve
    Do the headphone trick and you can use empirical proof:
    AX84.com - The Cooperative Tube Guitar Amp Project
      Thanks
      Thanks. I'll give this a try.
      Steve
        If the PT is Z-mount and the OT is X-mount, then their axis will already be oriented differently. 2CW
          Thanks
          Thanks,
          Steve
