Finally got around to finishing the Weber 6A14 kit I got last Oct (that I initially had a few teething probs with) this afternoon. (Its been sitting in my to-do pile for a few months while I've taken pecks at it now and again.) Anyhow its all finished and its all good.
Schematic attached (and soundbyte. FWIW the settings for the lead track were: vol-2, treb-7, bass-2, verb-3, speed and depth about 4 each, the rhythm track was dry - the thing was just dumped straight into garageband - with "RobO" drummer composed by moi - using the on-board mic on the mac - apologies for the recording quality and the musicianship )
The speaker is the Weber Sig 12S option with the kit and the OT is the 6k6 Pr Z that came with the kit.
The Weber PT got tossed out and replaced with a beefy NZ-made thing (values shown) with lots of iron (so it won't heat up - in fact I had it on for 2 hours this afternoon and the iron was only luke-warm). I reverted to the BFPR bias supply circuit (tapped off one side of the HT winding).
I did one of my own boards in the end and ended up changing the layout around quite a bit.
The trem is modified with the IRF820 source follower. The values are as shown. This gives quite a nice trem with no glitches.
Taking a cue from Merlin's excellent grounding article, the grounds are quite different from a BFPR ground return scheme. Every component on the board (and elsewhere in the amp) has its own separate grounding point going to the relevant filter cap ground return.
The filter cap can got tossed out and I put in separate filter caps and wired them with the grounds shown in the schematic and it is as quiet as a mouse.
There is an extra 10uF filter cap for the V1 tube (where the TS and vol pot grounds attach to).
The verb recovery triode and cathodyne triode and cathodyne driver triode grounds all go to the same 22uF filter cap ground. (The B+ supply for these stages is parallel with the B+ supply for the V1 stages.)
The 12AT7 grounds (incl the 12AT7 grid load resistor), and the RT secondary ground, together with the grounds for the entire LFO circuit, all return (by separate wires) to the same ground point (the screen node cap ground), because they all take their supply from the screen node.
